Discussion topic: No WiFi
Message posted on 19 Apr 2026 12:44 PM
No WiFi
The WiFi is down and I cannot connect. The WiFi indicator on the hub is is flashing rapid orange
Message posted on 19 Apr 2026 01:01 PM
Re: No WiFi
@Gaz+a+H
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
