1
This discussion topic has been answered Discussion topic: No WiFi
This message was authored by: Joanne78
No WiFi
Open reach box got one green light and one flashing green light
2 green light on hub
One orange light on hub
Re: No WiFi
@Joanne78
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Re: No WiFi
@Joanne78
