Discussion topic: No WiFi
This message was authored by: ethanhenry
No WiFi
My Hub shows Power- solid green, Wifi- solid green, internet- blinking orange. I have no WiFi in the house yet all the tests show good connection and no issues in my area?
Re: No WiFi
@ethanhenry
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
