Discussion topic: No WiFi
Message posted on 26 Sep 2025 10:26 AM
No WiFi
Good morning I'm sitting here in my house. I literally have no Wi-Fi connection every Wi-Fi box and booster has three green signals yet there is no Wi-Fi tested the broadband and the Wi-Fi. It says there's no issues but I have no Wi-Fi. The Wi-Fi has been in intermittently on and off dropping in and out for the past week and it says there is no issue right now but at this exact moment I'm talking to you there is no Wi-Fi in my house at all
Message posted on 26 Sep 2025 10:57 AM
Re: No WiFi
@Duthieseaview
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
