Discussion topic: No WiFi
Message posted on 21 Sep 2025 04:56 PM
No WiFi
Hi I have an orange light on my router and the WiFi will not work in the house
Message posted on 21 Sep 2025 05:17 PM
Re: No WiFi
@Linzi28
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
