Discussion topic: No WiFi
Message posted on 12 Sep 2025 03:02 AM
No WiFi
This is the second time this week this has happened. The first time you mended it without sending out an engineer. But it's happened again.
Message posted on 12 Sep 2025 03:42 AM
Re: No WiFi
@Suzanne+Gillett
In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If your broadband isn’t working in the morning use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
