1
This discussion topic has been answered Discussion topic: No WiFi
This message was authored by: Seanzy
No WiFi
Done all the checks and says WiFi is fine but unable to connect to WiFi and tells me to check Internet connection
Re: No WiFi
@Seanzy
Not sure what you have done so if a reboot of your hub at the mains doesn't kick it back into life then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Re: No WiFi
@Seanzy
