Discussion topic: No WiFi
Message posted on 24 Jun 2025 07:42 PM
No WiFi
Hi there is no WiFi. It is not working at all
Message posted on 24 Jun 2025 07:44 PM
Re: No WiFi
@Chewitt1
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
