Discussion topic: No WiFi
Message posted on 17 Jun 2025 05:04 PM
No WiFi
Message posted on 17 Jun 2025 05:46 PM
Re: No WiFi
@Mstatham
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
