Discussion topic: No WiFi
Message posted on 10 May 2025 12:06 AM
No WiFi
No wifi or internet connection,
Message posted on 10 May 2025 01:00 AM
Re: No WiFi
@SharonCraig1
If it's just gone down in the last couple of minutes it could be essential maintenance taking place which is carried out overnight to minimise disruption.
Otherwise, if you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
