Discussion topic: No WiFi
This message was authored by: Andy3333
No WiFi
My WiFi is on and not connecting to my sky box or my other devices. I have tried turning it off and on again.
Re: No WiFi
@Andy3333
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't come back on by 7am use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
