Discussion topic: No WiFi
This message was authored by: Chelseann8
No WiFi
Good afternoon we seem to have lost all internet connection from 3:20pm we have done all the checks to which it states there is no fault however no WiFi working on devices nor the tv - the sky box on the tv says no internet connection so can't work out why the runs have said no errors.
Re: No WiFi
@Chelseann8
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Re: No WiFi
@Chelseann8 Run a service check to see if sky are aware off any problems.
This message was authored by: Jlou
Re: No WiFi
I'm having the exact same issue, I've checked and it says there are no known issues, I've done all the fault checks and diagnostics etc and still can't get a connection.
WiFi is working on my phone and laptop but tv saying no internet connection.
this is the 3rd discussion forum today that says there are issues but yet Sky are saying no known issue
Re: No WiFi
@Jlou If you meant to or not but you need to clear your statement up, you have it working, it is just the TV that has a problem correct!!!
Re: No WiFi
No Jim, it isn't working despite trying everything and having to call Sky. They've booked a. Engineer to come out to investigate as the call handler agreed that something isnt right with the sky q connection
Re: No WiFi
@Jlou Thanks for replying, you posted multiple places with litlle/no information which is never good, as you have now stated you have Sky Q, is the satelite side working but not the internet connected that is the issue.
This message was authored by: RM1210
Re: No WiFi
My sky has been a pain for the past two days, service checker says everything is fine even claims I'm getting 152mbs download which I've never had. All my sky q boxes don't work iPads phones etc are sporadic it's a joke. Not sure what Sky is playing at but this is not working I've tried everything
This message was authored by: Polly653
Re: No WiFi
No WiFi
Re: No WiFi
@Polly653 Is it a NO wifi or a NO Broadband both are different, if an event from last night switch your hub off for 5 mins then back on see if it clears!
