Discussion topic: No WiFi
This message was authored by: Scammell
No WiFi
My WiFi isn't working, it has been dropping out and been slow all week, now it's completely stopped working. I've reset it router and sky q tv boxes and still not working. When I run WiFi checker tests it says it's all working and connected. On sky q tv box it says I'm not connected and it can't find my WiFi. All green lights are on on my router and saying it's working.
Re: No WiFi
@Scammell
