Discussion topic: No WiFi working at home
Message posted on 13 Aug 2026 06:30 PM
We need our WiFi tested as saying theirs no problem
biy nothing is working
Message posted on 13 Aug 2026 06:36 PM
Re: No WiFi working at home
Wi-Fiband broadband are different.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
