Discussion topic: No WiFi signal
This message was authored by: Sue--
No WiFi signal
I have a red light on open reach box and sky box is fading in and out green
Re: No WiFi signal
@Sue--
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
▪️I AM NOT A SKY EMPLOYEE ▪️
