Discussion topic: No WiFi green light is flashing
Message posted on 06 Jul 2026 08:06 PM
Major outage since 5pm came back on hour ago but gone off again.. how long before outage is fixed
Message posted on 06 Jul 2026 08:07 PM
Re: No WiFi green light is flashing
@Danielle13x1
You may not be aware but you haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
