Discussion topic: No WiFi for 24 hours
Message posted on 26 Feb 2026 07:35 PM
Our WiFi hasn't been working for the last day but when we do the checks it says it's fine. After we turn everything off and on again we get 5 minutes and that's it. Please help as we work from home and urgently need WiFi. It's very frustrating that the checker says it's fine.
Message posted on 26 Feb 2026 07:38 PM
Re: No WiFi for 24 hours
@Jonnu
You may not be aware but you haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
