Discussion topic: No WiFi for 2 days
This message was authored by: DonnaK2
No WiFi for 2 days
We've had no WiFi for 2 days
Re: No WiFi for 2 days
@DonnaK2
Have you reported it to Sky in those two days?
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
