1
This discussion topic has been answered Discussion topic: No WiFi connection
This message was authored by: Gjen111
No WiFi connection
my WiFi has been down since 19:06. There's an orange light in my hub above the hub which isn't usually on. I've disconnected and restarted everything, still I have no WiFi. I've tested the hub connection on the sky app and it says there's no issues in the area and the connection is good, still I have no WiFi. Please can you advise?
Re: No WiFi connection
@Gjen111
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
@Gjen111
