Discussion topic: No WiFi connection.
This message was authored by: Emma_incognito
No WiFi connection.
WiFi will not connect to my tv or phone. Shows as no Internet. Connected to router but no Internet.
Re: No WiFi connection.
@Emma_incognito
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
This message was authored by: stupatterson
Mine out as well open reach box shows red PON means no bb coming into home.
Sky checker says all good. It's obviously wrong
@stupatterson
The service checker doesn't necessarily disclose a problem immediately and there can be up to an hours delay before it picks up a lost connection which is why, on here, we tend to advise on trying it again later.
