Discussion topic: No WiFi connection
This message was authored by: PRIESH
No WiFi connection
No WiFi connection I'm SKY VIP CUSTOMER but no help from sky.. very very disappointed
Re: No WiFi connection
@PRIESH
Almost all Sky customers are classed as being V.I.P, customers.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
