Discussion topic: No WiFi connection
Message posted on 18 Apr 2024 11:56 PM
No WiFi connection
I've currently got no WiFi and haven't had it for the last couple of hours
Message posted on 19 Apr 2024 07:44 AM
Re: No WiFi connection
@JC351 do you really mean Wifi in your home or are you saying that your Sky hub has lost the internet connection the two are quite different. If you mean the latter, the connection is still down this morning and the My Sky app test run over a mobile connection doesnt tell you there is a known fault call Sky to report it. Given there appears to be a fault affecting the area around St Helens Sky's customer services will be busy.
Message posted on 19 Apr 2024 07:50 AM
I have no WiFi connection!! Which is affecting my sky streaming!! Only had all this put on 2 weeks ago!!
