Discussion topic: No WiFi bedroom
This message was authored by: Debs811
Message posted on 10 May 2026 07:42 PM
No WiFi bedroom
I don't get signal to join the wifi in my bedroom.
Find out more
Message posted on 10 May 2026 07:44 PM
Re: No WiFi bedroom
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
