Discussion topic: No WiFi although no issues showing
Message posted on 16 Aug 2026 11:27 PM
Sky checker saying no issues but WiFi not working for tv or on phone.
Interestingly, had to turn off WiFi and use 5g on phone to get signal for sky to tell me no issues?! Make it make sense!
Message posted on 17 Aug 2026 03:37 AM
Re: No WiFi although no issues showing
Broadband and Wi-Fi are different.
Start by using this link to check if there are any broadband issues locally that may identify a known fault which could be affecting multiple households ~
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
