Discussion topic: No WiFi a
This message was authored by: Ash387
No WiFi a
No WiFi
Re: No WiFi a
@Ash387
If you have broadband issues between midnight and 0700 it’s likely to be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
If it's not back in the morning use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
