Discussion topic: No WiFi. Orange light on router
Message posted on 05 Dec 2025 07:35 AM
Message posted on 05 Dec 2025 07:37 AM
Re: No WiFi. Orange light on router
@Kauser52
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
