Discussion topic: No WiFi Internet connection NR1
Message posted on 06 Jul 2026 09:48 PM
Rebooted hub 3x and red light and no Internet connection remains??
Message posted on 06 Jul 2026 10:30 PM
Re: No WiFi Internet connection NR1
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Message posted on 07 Jul 2026 05:47 AM
Have completed all this but says all fine yet when go to connect device it says connected without Internet and last dot on hub still red
Message posted on 07 Jul 2026 07:42 AM
This link explains the lights on the various hubs
Message posted on 07 Jul 2026 01:27 PM
Yep realised its the voice light at the end that not green... have runaway ll the tested disconnected power supply reconnected, pressed reset, used the tools though thy say all is good! Yet still have not Internet via WiFi for the amazon firestick on Telly or to my mobile phone ???
#day2 #frustrated
@Atm70 wrote:Rebooted hub 3x and red light and no Internet connection remains??
rustrated
