Discussion topic: No WiFi East Sussex Hastings
This message was authored by: Kev3uk81
Hey, anyone have an issue with their wifi, my dad is in Hastings East Sussex and has an issue with no WiFi, when I do the service checker it shows red and there's a problem, upon testing connection it then goes green and says no issues but it still isn't actually working
Re: No WiFi East Sussex Hastings
@Kev3uk81   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for Kev3uk81
Thanks, I've already done all that, it states no issues in the area and shows red that there's a problem, click on the let's fix it box which makes it go green and says it's fixed but it isn't, ten minutes later on another test it's back to red, it won't actually fail a test to trigger the engineer option
