Discussion topic: No Wi-Fi
This message was authored by: Jacque21
No Wi-Fi
Cant get to the box to turn off as behind a kitchen unit
Re: No Wi-Fi
@Jacque21
What box has been put behind a kitchen unit?
Avatar for Jacque21
No broadband
Broadband keep coming on then few hours later off
Re: No broadband
@Jacque21
Your new thread has been merged into the first one to prevent duplication of replies.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Re: No Wi-Fi
That's rather unwise: such devices may well need rebooting on occasion.
I suppose in theory cutting power to the ring which the socket is on should have the same effect.
