Discussion topic: No Wi-Fi
This message was authored by: William9X9X
No Wi-Fi
Report says All OK, but there is no Wi-Fi connection.
Re: No Wi-Fi
@William9X9X
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Avatar for William9X9X
Re: No Wi-Fi
Broadband and Wi-Fi test and 'look' OK.  Still No Connection so cannot access the internet.  Now using my neighbour' connection.
This message was authored by: SHIVA231
Re: No Wi-Fi
I am also having the same issues
This message was authored by: EllaC
Re: No Wi-Fi
I’m also having the same issue in Northumberland. Ran the checks on the app and it says everything is fine but none of my devices will connect to the Wi-Fi. Extremely frustrating.
