Discussion topic: No Wi-Fi
This message was authored by: Daniel137
No Wi-Fi
Internet not working
This message was authored by: Samantha118
Re: No Wi-Fi
Mines been so slow since Christmas Eve, I've tried turning it on & off again but nothing, tbh it's not been great since upgrading a few months back but now I'm getting absolutely no use from it?! HELP?!
Re: No Wi-Fi
@Daniel137
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Once completed, if it reports back that all is good click on 'broadband' to run an updated test. If you get amber or red you need to follow the on-screen instructions.
This message was authored by: Vixx
Re: No Wi-Fi
There are many of us in my area all saying the same, sky went down yesterday morning and it's still off, almost 24hrs later.
service checker says there is no issues in our area.
the other link tells me there is an issue with my hub, I follow the instructions and then I get the message that sky are having technical issues and to come back later to test again.
same message I've had for almost 24hrs.
it isn't just me otherwise I'd have put the blame on a dodgy hub!
