Discussion topic: No Wi-Fi conn
Message posted on 07 Feb 2025 10:30 AM
No Wi-Fi conn
Sky internet box making loud noise keep losing connection to internet very very slow when connected
Message posted on 07 Feb 2025 11:00 AM
Re: No Wi-Fi conn
@Nicola147
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
