2
This discussion topic has been answered Discussion topic: No WIFI inside my house
This message was authored by: CBD99
Tests all day everything is good but there is no WiFi.
Re: No WIFI inside my house
@CBD99
No Wi-Fi or no broadband?
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
@CBD99
Avatar for CBD99
Thank you. I did try all the steps but with no joy. Customer services gave different reasons but I've been without WiFi for 5 days now. I'll call them again after work.
