Discussion topic: No WIFI CONNECTION
This message was authored by: Diane80
No WIFI CONNECTION
Hi I woke up this morning to no WiFi. Unable to watch tv. Done all the usual restarting etc. Still nothing and wife address not appearing on the screen to connect. Check the connection on the wall and 3 out of 4 lights on. The light not on is LOS Any advice please
Re: No WIFI CONNECTION
@Diane80What colour are the lights on the router and which one is not on?
Avatar for Diane80
I have the new white router and the light is white which is correct. When I look at the open reach box on the wall there's 4 lights green. 3 lights lit apart from the LOS which has no colour
@Diane80  That is  how it should look on the ONT. If you have no Wi-Fi connection are you talking about that your devices cannot see the Wi-Fi name at all?
Avatar for Diane80
No WiFi name coming up and tried to add manually and said could not connect.
The LOS light is always lit green in the past
@Diane80  Can you please try and factory reset the router to see if this brings back the Wi-Fi name on your devices.
Avatar for Diane80
This has been done half a dozen times.
