Discussion topic: No Internett
Message posted on 15 May 2026 06:43 AM
No Internett
Im trying to work from home but have no internett what is goin gon since yesterday
Message posted on 15 May 2026 07:08 AM
Re: No Internett
@Julie344
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
