Discussion topic: No Internet/wifi
Message posted on 16 Jun 2025 01:09 PM
No Internet/wifi
Message posted on 16 Jun 2025 01:16 PM
Re: No Internet/wifi
@Smallmanbod Is there an issue in your area:
https://www.sky.com/help/servicestatus/broadband-and-talk
If not, try troubleshooting here:
https://www.sky.com/help/articles/connect-devices-to-broadband-fix-which-device
Message posted on 16 Jun 2025 01:24 PM
@Smallmanbod
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
