Discussion topic: No Internet or phone connection
Message posted on 01 Mar 2025 12:22 PM
Message posted on 01 Mar 2025 12:45 PM
Re: No Internet or phone connection
@heather_hughes
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
