Discussion topic: No Internet on hub
Message posted on 28 Feb 2025 02:33 PM
No Internet on hub
Internet light is amber done all tests and reset but no connection 😕
Message posted on 28 Feb 2025 02:34 PM
Re: No Internet on hub
@Beeonya
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline [if it’s still working]).
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
Message posted on 28 Feb 2025 02:41 PM
Is there a number I can call from a mobile as have no home phone?
Message posted on 28 Feb 2025 02:42 PM
@Beeonya
To call Sky dial 150 (free) from a Sky Talk landline or a Sky mobile or alternatively use the following link
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ leading to a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ to see a dedicated ROI number.
The posting of full phone numbers isn’t permitted on the forum.
Calls to Sky will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
