Discussion topic: No Internet for two days
This message was authored by: Gavinppppp
My Internet hasnt been working since yesterday at 3pm
Re: No Internet for two days
@Gavinppppp
Have you rung Sky in the last 25 hours (not two days)?
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline [if it’s still working]).
