Discussion topic: No Internet connection
Message posted on 19 May 2026 08:49 PM
At around 8.00pm, my Internet lost connection. I unplugged the router and plugged it in again and nothing changed. I checked the service checker, which says nothing is wrong. But, the Internet light is flashing amber.
Message posted on 19 May 2026 08:53 PM
Re: No Internet connection
@Tox
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
