Discussion topic: No Internet connection
Message posted on 19 May 2026 11:16 AM
Message posted on 19 May 2026 11:26 AM
Re: No Internet connection
@Neena
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
