Discussion topic: No Internet connection
This message was authored by: Knee
My Internet has not been working for the last two days. I have gone through all the checks according to the app and it is still not working. none of my device devices will connect
Re: No Internet connection
@Knee
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
