Discussion topic: No Internet connection
Message posted on 24 Aug 2025 09:00 PM
Message posted on 24 Aug 2025 09:31 PM
Re: No Internet connection
Pure coincidence. A big company like Sky have no need to operate like that.
Used this link again to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 24 Aug 2025 09:31 PM - last edited: 24 Aug 2025 09:32 PM
@Emi91 wrote:
Anyone else got the same or anyone have any suggestions of how to fix this without having to wait 2 weeks for enginee
If there's a fault in the external Openreach circuit (which is where most such problems occur) then you've no option but to wait: the target time to fix would be two working days.
And yes, it's 'coincidental' as in happening at the same time for unrelated reasons.
