Discussion topic: No Internet connection
Message posted on 21 Jul 2025 01:22 PM
Broadband router connected but no connection to internet
Message posted on 21 Jul 2025 01:27 PM
Re: No Internet connection
@LouiseCaballos
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
