Discussion topic: No Internet connection
Message posted on 07 Feb 2025 09:46 AM
No Internet or WiFi or television
Message posted on 07 Feb 2025 11:06 AM
Re: No Internet connection
@Brown_Keer
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
