Discussion topic: No Internet connection
Message posted on 11 Oct 2024 12:18 PM
Re: No Internet connection
I should have added, I am also in the ME16 area
Message posted on 11 Oct 2024 06:13 PM
Very slow running at half correct speed in TH21
Message posted on 13 Oct 2024 12:46 PM
I am having an issue connecting to the internet. This is causing issues.
Message posted on 13 Oct 2024 12:56 PM
My internet will not connect.
Message posted on 13 Oct 2024 06:34 PM
No internet
Message posted on 13 Oct 2024 06:35 PM
I'm not sure what kind of help I will get
Message posted on 14 Oct 2024 01:05 AM
I've also had no internet since 11/10/24 absolute joke
Message posted on 15 Oct 2024 06:23 PM
No internet Aberdeen
Message posted on 17 Oct 2024 09:05 PM
Just incase anyone else is having the same issue again. Our internet just went down another time, same lights showing etc. when this happened last week, the advisor sent out a new router, by the time it got here the Internet was running again so we left it be; it's just cut out again so we took the opportunity to switch it out and it's back working perfectly... May be worth a go requesting new if this has happened to any of you again 🙂
Message posted on 27 Oct 2024 01:45 PM
Same problem as above Billericay
Message posted on 28 Oct 2024 09:59 AM
Well we finally got our internet back after problems over a long period of time. An Outreach engineer finally found a fault in the connecting cable within a metre of the house. Although the signal line checked out good getting 75Mb/s with his test gear. He did a further continuity fault line check from the house and discoverd the fault. Well done that man {Alvin} he was determined not to leave until the problem was solved. Everything is now working well.
Message posted on 28 Oct 2024 12:37 PM
Open Reach are due to send an engineer out to source a fault between the cabinet and master socket in my house, so hopefully Alvin shows up and does as a good a job as he did for you, as my speeds have been terrible ever since the WiFi went down weeks ago for 4 straight days and came back up providing my around 7 Mbps.
Message posted on 07 Nov 2024 08:34 PM
And Fulham
Message posted on 13 Nov 2024 09:34 PM
Also in DE11
Message posted on 18 Nov 2024 01:46 AM
I have a similar issue, my internet has gone off too. It was on fine 45 minutes ago now it has no internet connection. I have turned it off and restarted it however still no internet connection
