Discussion topic: No Internet Connection
This message was authored by: GSc15
Third time this week I have encountered an orange light on my Sky Hub on the "Voice" and a loss of internet with flashing orange "Internet" light, solid orange light or no light at all. This occurrence has been ongoing for over twenty minutes where previously the downtime in service has been limited to a maximum of ten minutes.
Re: No Internet Connection
@GSc15
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
