Discussion topic: No Internet Connection
This message was authored by: John+Davis
Hi, I've lost Internet connection and have followed reset process but nothing is happening. When I've checked my connection status on MySky it says everything is ok...but I'm still unable to get Internet access. Please help as I need to have connection as I work from home!!
This message was authored by: ayesha4395
Re: No Internet Connection
me too!!
This message was authored by: Louise199208
It seems to be down across the UK in most areas
This message was authored by: HannahB33
Exactly the same for me, tried all the options and nothing is helping but my service checker says its all ok??
This message was authored by: Shar17
It the same for me.
This message was authored by: sarahlee70
Mine has finally signed in
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If not, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
