Discussion topic: No Broadband
This message was authored by: UrbanT
No Broadband
I have no broadband in Ealing Broadway since an hour. Red light at socket and orange light on router. Sky test app says all ok. Clearly it isn't. Happy to share photos. Any advice
Re: No Broadband
@UrbanT
