2
This discussion topic has been answered Discussion topic: No Broadband
This message was authored by: Spocksavulcan
No Broadband
Broadband went down over an hour ago and despite resetting it is still out. Checker is alternating between everything is ok to there is a problem.
Re: No Broadband
@Spocksavulcan
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Re: No Broadband
@Spocksavulcan
Avatar for Spocksavulcan
Re: No Broadband
Broadband eventually came back on by itself about 2 1/2 hrs later.
Thanks for trying to help.
